[postgis-devel] release status
strk at refractions.net strk at refractions.net
Mon Feb 14 01:43:46 PST 2005
It's almost one month since RC2 is out, and we have
a bounce of changes logged:
        - transform(): missing SRID bugfix, better error handling
        - jdbc2: small patches, box2d/3d tests, revised docs and license.
        - jdbc2: bug fix and testcase in for pgjdbc 8.0 type autoregistration
        - few changes in autoconf
        - reduced precision of box2d output.
        - some functions made IMMUTABLE from STABLE,
          for performance improvement
        - new performance tips chapter in manual
        - BUILDDATE extraction made more portable
        - fixed bogus 72 index bindings
        - prefixed DEBUG macros with PGIS_ to avoid clash with pgsql one
        - fixes in probe_geometry_columns() to work with PG72 and support
          multiple geometry columns in a single table
        - fixed spatial_ref_sys.sql to avoid vacuuming the whole database.
        - jdbc2: Removed use of jdk1.4 only features to enable build with
          older jdk releases.
        - jdbc2: Added support for building against pg72jdbc2.jar
        - documentation updates: pgsql72 requirement, lwpostgis.sql
        - memory alignment handling
The "segfaulting points" issue seems to be fixed (memory alignment
handling), but the following issues are still open:
	- mapserver connector weidness
	- spatial_ref_sys entries (compatibility ?)
I think the special handling of the SRID=-1 should wait until 1.1.0,
as getting 1.0.0 out is already taking too much time, so I removed
it from the list of "open issues" (it's a feature request).
If anyone has reports about mapserver connectivity or hints about
new proj4 entries please send them out. I'd tag and boundle RC3
this week.
--strk;
On Tue, Feb 08, 2005 at 09:11:29AM +0100, strk at refractions.net wrote:
> Update changes:
> Updated open issues:
>         - segfaulting points
>         - mapserver connector weirdnesses
> 	- spatial_ref_sys entries (incompatible between PROJ versions?)
>         - SRID=-1 special handling
> --strk;
> On Mon, Feb 07, 2005 at 01:25:41PM +0100, strk at refractions.net wrote:
> > 12 days has gone since RC2.
> > This are changes so far:
> > This are the open issues in order of importance:
> > It would be useful to have most informations about the bugs handy.
> > Paul, what about linking the bug tracker on the postgis web site ?
> > Is anyone experiencing the points bug on this list ?
> > --strk;
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
