[postgis-devel] Geos_noop memory leak?
Markus Schaber
schabios at logi-track.com
Thu Feb 17 07:23:53 PST 2005
I think I might have found a memory leak in geos_noop.
This is my postmaster backend process after calling some non-geos GIS
functions:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
6870 postgres 25 0 23784 8700 7760 S 0.0 0.8 0:35.81 postmaster
All three of VIRT, RES and SHR increased a lot during running the query,
and dropped again when the query was finished. There is a small increase
in RES and SHR memory usage after the _first_ call of each function,
which seems to be caused by PostgreSQL loading the C function into
memory. The memory usage keeps constant for repeated calls of the same
function, or alternatinly calling already-initialized functions.
Now the same process after calling "select geosnoop(geom) from adminbndy1;":
6870 postgres 25 0 138m 123m 7800 S 0.0 12.3 1:40.91 postmaster
And after issuing the query a second time:
6870 postgres 25 0 248m 233m 7800 S 0.0 23.1 2:07.31 postmaster
Can anyone reproduce this? Does this occur with other GEOS functions, too?
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050217/7ee750b2/attachment.pgp>
