[postgis-devel] Re: postgis failure on debian woody
Markus Schaber
schabios at logi-track.com
Tue Feb 22 10:00:11 PST 2005
Hi, Alex,
alexbodn at 012.net.il schrieb:
>> cp postgis.jar postgis_debug.jar cd $(SRCDIR) && $(ZIP) -u -r -q
>> ../postgis_debug.jar .
> i am sure it will work, since zip is even more portable then java.
> but zip is not standard on java, or even of unix, so that we might
> overimpose the fastjar limitation on all postgis users.
That's right, adding an additional build dependancy is always bad.
> is my proposal really that ugly?
Well, IMHO, having to care about -u at all is ugly :-)
And the fastjar having the -u option documented when running "fastjar
-help", but then abort with "fastjar: `-u' mode unimplemented." when I
actually use it, is _really_ ugly!
BTW, I just noticed that the sun jdk 1.1 that is part of woody/non-free
brings a jar that does not understand -u either.
I just committed an updated jdbc2/Makefile:
- more comments
- all helper binaries are now configurable (I missed cp before)
- workaround for broken woody jars via DEBUGJAR environment variable
- classpath cleanups, regression tests now use jars instead of build
directory, this should help catching packaging errors
- small other cleanups
Alex, could you test whether it works on all your environments (with
appropriate CLASSPATH, JAR and DEBUGJAR settings)?
Strk, does it still work for you?
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050222/eb3ddc5f/attachment.pgp>
