[postgis-devel] postgis_lib_build_date(), postgis_scripts_build_date()
strk at refractions.net strk at refractions.net
Tue Jan 11 09:40:27 PST 2005
I've committed a 2005-01-11 17:12:10 version, changing
sed command to allow ':' in input.
--strk;
On Tue, Jan 11, 2005 at 06:24:46PM +0100, Markus Schaber wrote:
> Hi, strk,
> On Tue, 11 Jan 2005 18:15:43 +0100
> strk at refractions.net wrote:
> > It's good, just, wouldn't 20050111171210 be a more
> > machine-parsable info or 2005-01-11 17:12:10 a more
> > human readable one ?
> I originally used the second one, but sed had problems with the : in the
> rules, because it has a special meaning. But at least a blank between
> date and time would increase the readibility a lot, IMHO. I left it out
> because I wanted to keep the token after BUILD= as a single word, but as
> this is a String on its own now, I do not see any problem. So you could
> use the following in the makefile:
> POSTGIS_BUILD_DATE := $(shell date -u "+%F %H-%M-%S")
> Thanks,
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
