[postgis-devel] PATCH: New positional operators based on Y position of bounding boxes
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Jan 12 03:31:46 PST 2005
Hi strk,
> -----Original Message-----
> From: strk at refractions.net [mailto:strk at refractions.net]
> Sent: 12 January 2005 09:38
> To: Mark Cave-Ayland
> Cc: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] PATCH: New positional operators
(cut)
> I've been asked to research on this for GUI applications, and
> for that use the 'estimated' extent is ok (somehow better, if
> you consider hard-deviants). It works even in absence of a
> GiST index (stats are computed anyway), but only for PG8+.
> Your version would be more widely usable (PG<80) and more
> accurate, but would require a GiST index. I imagine it could
> work transparently from inside extent() - using GiST if
> available, and brute force otherwise.
I think I would envisage it as a separate function, something like
column_extent(), since people would still need to use extent() for
sub-selects, which will probably only make the code messier - it would also
mean we could point out obvious mistakes where people are trying to use
column_extent() in sub-selects and wondering why they are getting the wrong
result ;)
The other thing to consider would be to re-write the stats code so that PG80
and < PG80 share the same code. As far as I can see, the only difference
between the two versions should be where the data comes from - in the case
of PG80 it is the pg_statistic table, whereas for PG < 80 it is the
geometry_columns table.
The ideal would be to take your (very good) statistical routines and
abstract them so that they use a separate function to fetch/store the data
for a column; the main routines would work using a pointer to an array of
palloc'd floats. It would then only be the fetch/store routines that would
be different, which would need to read/write the float arrays to either
pg_statistic or geometry_columns depending upon the correct version. It
should then be fairly trivial to get the estimated_extent() working for PG <
80, and would mean we could remove a lot of duplicate code from
lwgeom_estimate.c. This definitely something worth doing before we hit RC
stage IMHO.
> Probably we should not rush to have this included in RC1, but
> I'll make some tests with it.
I agree. I don't think it's worth delaying going to RC because of it - we
can always work on it here on the development list and then commit it when
it's ready.
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
