[postgis-devel] GiST estimate and index_extent()
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Thu Jan 13 05:25:40 PST 2005
Hi strk,
> -----Original Message-----
> From: strk at refractions.net [mailto:strk at refractions.net]
> Sent: 13 January 2005 11:08
> To: Mark Cave-Ayland
> Cc: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] GiST estimate and index_extent()
> Mark,
> Paul actually did not express his preference about this, and
> actually I'm not convinced as well... I'm not sure 2 days
> will be enough, not for the implementation but for the
> decisions reguarding backward-compatibility. If we find a
> clean solution today I think that would be ok.
> We currently have a fix_geometry_columns() which fixes
> f_table_schema, attrelid and varattnum. The function is
> automatically invoked by AddGeometryColumn() and
> update_geometry_stats().
> What we could do is drop the automatic invokation and improve
> it to drop attrelid, varattnum and stats if present for
> PG>=800 and to change stats into a stakind1 smalint /
> stanumbers1 float[] for PG<800 if stats is present. Note that
> in this case the HISTOGRAM2D type would be pretty useless, so
> we could drop it as well.
Note that we don't need to convert old stats into float[] because once a
database has been restored the user would have to VACUUM ANALYZE anyway
which would automatically generate a new histogram. And yes, we could drop
the HISTOGRAM2D type.
> About TODOs, running regression tests I found that lwgparser
> does not check polygon validity as did HWGEOM do. Maybe that
> should be added, but I guess could wait for 1.0 or RC2.
> Comments ?
If this could cause us to allow invalid geometries into PostGIS then my call
would be to fix it so we can help protect users from themselves! I don't
think this will be too difficult for anyone with experience with
lexers/parsers....
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
