[postgis-devel] JDBC updates
strk at refractions.net strk at refractions.net
Tue Jan 18 05:03:59 PST 2005
Markus, I'm not a Java hacker, but I'm trying to at least build
the driver. The first thing I note is that you're still using
PSQLException, while you should be using SQLException.
If you look at ChangeLog:
2004-10-06 00:46  strk
        * org/postgis/Point.java: Removed PGSQLException use as suggested
        by Kris Jurka
Dunno which pgsql versions do need SQLException and which PSQLException.
--strk;
On Mon, Jan 17, 2005 at 06:17:32PM +0100, Markus Schaber wrote:
> Hello,
> I attached my first alpha release of my PostGIS JDBC extension rework.
> It does not yet pass all regression tests (mainly because the servers do
> not accept what I feed them in WKT format) - it is still to be
> determined who's wrong here. It seems that PostGIS 1.0CVS has problems
> in reading all MULTI* Geometries, while PostGIS 0.8 only has problems
> when several MULTI* of the same type are combined.
> Feel free to post comments and bug-fixes, although I know that I still
> have some work to to until this can be released.
> HTH,
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
