[postgis-devel] JDBC updates
strk at refractions.net strk at refractions.net
Tue Jan 18 05:50:21 PST 2005
On Tue, Jan 18, 2005 at 02:43:22PM +0100, Markus Schaber wrote:
> Hello,
> Markus Schaber schrieb:
> > I attached my first alpha release of my PostGIS JDBC extension rework.
> If you try to build it, please notice that the Makefile is out of sync
> (I did not update it although I changed the file layout), and the ant
> script is not tested. (I use eclipse which automatically builds it.)
> For the next release, I'll fix the ant file, but I do not know whether
> we should drop the Makefile completely (for the JDBC part).
Here is how I fixed the Makefile, Note that SRC and EXAMPLES must
point in the correct directory.
diff -rU2 jdbc/Makefile jdbc-strk/Makefile
--- jdbc/Makefile       Tue Oct 19 23:26:46 2004
+++ jdbc-strk/Makefile  Tue Jan 18 14:47:15 2005
@@ -3,5 +3,7 @@
 JAR = jar
 #CLASSPATH = /home/pramsey/geotools/extbin/postgis/lib/postgresql.jar:
-CLASSPATH=$CLASSPATH:.:/usr/share/java/postgresql.jar
+CLASSPATH+=:src:/usr/share/java/postgresql.jar
+SRC=src
+EXAMPLES=../../examples
@@ -11,30 +13,30 @@
 jar:
-       $(JAR) -cf postgis.jar org/postgis/*.java org/postgis/*.class README
+       $(JAR) -cf postgis.jar /org/postgis/*.java org/postgis/*.class README
 ogis:
        $(JAVAC) -classpath $(CLASSPATH) \
-               org/postgis/Geometry.java \
-               org/postgis/Point.java \
-               org/postgis/MultiPoint.java \
-               org/postgis/LineString.java \
-               org/postgis/MultiLineString.java \
-               org/postgis/LinearRing.java \
-               org/postgis/Polygon.java \
-               org/postgis/MultiPolygon.java
+               $(SRC)/org/postgis/Geometry.java \
+               $(SRC)/org/postgis/Point.java \
+               $(SRC)/org/postgis/MultiPoint.java \
+               $(SRC)/org/postgis/LineString.java \
+               $(SRC)/org/postgis/MultiLineString.java \
+               $(SRC)/org/postgis/LinearRing.java \
+               $(SRC)/org/postgis/Polygon.java \
+               $(SRC)/org/postgis/MultiPolygon.java
 pgobjs:
-               org/postgis/PGgeometry.java \
-               org/postgis/PGbox3d.java
+               $(SRC)/org/postgis/PGgeometry.java \
+               $(SRC)/org/postgis/PGbox3d.java
 test:
-       $(JAVAC) -classpath $(CLASSPATH) examples/Test.java
-       $(JAVA) -classpath $(CLASSPATH) examples/Test
+       $(JAVAC) -classpath $(CLASSPATH) $(EXAMPLES)/Test.java
+       $(JAVA) -classpath $(CLASSPATH) $(EXAMPELS)/Test
 jtest:
-       $(JAVAC) -classpath $(CLASSPATH) examples/TestServer.java
-       $(JAVA) -classpath $(CLASSPATH) examples/TestServer
+       $(JAVAC) -classpath $(CLASSPATH) $(EXAMPLES)/TestServer.java
+       $(JAVA) -classpath $(CLASSPATH) $(EXAMPLES)/TestServer
--strk;
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
