[postgis-devel] autoconf
strk at refractions.net strk at refractions.net
Mon Jan 24 05:47:40 PST 2005
I've added in CVS an initial configure script, aimed at
reducing format errors in Makefile.config.
Run autoconf to obtain a configure from configure.in.
Then you can use ./configure \
	--with-geos=path_to_geos-config \
	--with-proj=PROJ_DIR \
	--with-pgsql-src=PGSQL_SRC_DIR
Note that so far there are no autodetects, just checks on
provided paths. As before environmental variables are honoured
(at configure time, not later).
The configure script will print a summary of configured paths.
Comments welcome
--strk;
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
