[postgis-devel] autoconf
TECHER Jean David davidtecher at yahoo.fr
Mon Jan 24 06:10:19 PST 2005
strk:
did you update the doc for autoconf???
TECHER Jean David
Responsable Informatique 01MAP
e-mail: davidtecher at yahoo.fr
Bureau: 04 67 45 60 27
Portable: 06 85 37 36 75
site perso : http://techer.pascal.free.fr/postgis/
site pro: http://www.01map.com/download/
K-S:"The greatest trick the devil pulled off was convincing people he didn't
exist"
----- Original Message -----
To: <postgis-devel at postgis.refractions.net>
Sent: Monday, January 24, 2005 2:47 PM
Subject: [postgis-devel] autoconf
> I've added in CVS an initial configure script, aimed at
> reducing format errors in Makefile.config.
> Run autoconf to obtain a configure from configure.in.
> Then you can use ./configure \
> --with-geos=path_to_geos-config \
> --with-proj=PROJ_DIR \
> --with-pgsql-src=PGSQL_SRC_DIR
> Note that so far there are no autodetects, just checks on
> provided paths. As before environmental variables are honoured
> (at configure time, not later).
> The configure script will print a summary of configured paths.
> Comments welcome
> --strk;
> For standing up against patentability of software,
>   Thank You, Poland!
> Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
> Send your thanks:         thankyoupoland.info
> Read/do more:   http://www.noepatents.org/
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
