[postgis-devel] Small jdbc2 patch
Markus Schaber
schabios at logi-track.com
Fri Jan 28 06:04:52 PST 2005
I attached a small patch to jdbc2 code. It changes three minor things:
- Add another item to the todo list.
- A small hack to cut traling ".0" on integer coordinates on WKT output.
As it makes things (slightly) slower, you can change Point.CUTINTS to
false. As it is static final, the compiler optimizer eliminates the
calls to cutint() altogether.
- Removed some debug variables from ValueGetter.java
BTW, as I got no feedback from users up to now: Did anyone besides strk
and me actually test or use this code? Are we the only PostGIS JDBC
users altogether?
Thanks,
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050128/02cc021b/attachment.txt>
