[postgis-devel] POSTGIS pre_1_0_2_rc1
strk at refractions.net strk at refractions.net
Fri Jul 1 02:27:24 PDT 2005
On Thu, Jun 30, 2005 at 02:04:10PM +0200, Jean David TECHER wrote:
> Hi Sandro
> On Windows
> I've a little problem with lwpostgis.sql
> for example my liblwgeom.1.1.dll is in /c/PostgreSQL/8.0.3/libexec
> when I did
> psql -d mydb -f c:\PostgreSQL\8.0.3\share\postgis\lwpostgis.sql
> on DOS or MINGW I got error
> The only solution in lwpostgis.sql is to replace '/c/' by 'c:/'
> Perhaps the better solution is to replace the path by the variable $libdir as usual
> it works fine for $libdir
It will be $libdir if you don't use the --prefix switch.
If you DO use --prefix then it will be $libexecdir.
Did you use /c/... for --prefix ?
Can you try using c:/... instead ?
--strk;
