[postgis-devel] postgis 1.1.0 / postgis 1.0.2
strk at refractions.net strk at refractions.net
Mon Jul 4 02:17:07 PDT 2005
On Mon, Jul 04, 2005 at 10:57:42AM +0200, Jean David TECHER wrote:
> Hi Sandro
> On Windows
> cvs update -r pgis_1_0.................works fine for configure , make and make install
> with pg 8.0.3, geos cvs and proj 4.4.9
> test regression (postgis/regress) and personal test............OK
> loader shp2pgsql with switch -I on 25 shapefiles....................OK
> pgsql2shp ............................................OK
> Do U need others test? Let me know
I think it's enough, thanks!
BTW, you still shouldn't be using configure until 1.1 :P
--strk;
