[postgis-devel] ICONV autodetection (head branch)
strk at refractions.net strk at refractions.net
Mon Jul 4 02:48:24 PDT 2005
On Thu, Jun 30, 2005 at 10:36:11AM +0200, Jean David TECHER wrote:
> Sorry for iconv I've had problem so I put USE_ICONV=0 in postgis/Makefile.config.in
> Make and make install works fine!!!
I've reworked iconv detection code to be more conservative.
It should now be enabled only if the c library provide that functionality.
(no external libiconv supported).
This should remove the need of manually edit Makefile.config
--strk;
