[postgis-devel] ICONV autodetection (head branch)
strk at refractions.net
Mon Jul 4 10:05:43 PDT 2005
David, I've cleaned up the scripts some more so to use
more facilities offered by Makefile.shlib.
Can you try again and report any problem ? I think we should
--strk;
On Mon, Jul 04, 2005 at 03:44:10PM +0200, Jean David TECHER wrote:
> Ok. Correct me if I'm wrong.
> First patch is USE_ICONV=0 forced, which shouldn't be needed anymore
> U're right
> This is an old patch I did before U made iconv optionnal last week...so it is a old patch
> Second patch is against Makefile.shlib, which should have been
> copied from postgresql sourced
> I know but I had to modify few lines on it...difference between 'SHLIB' and 'shlib' fro example
> TECHER Jean David
> 01MAP
> e-mail: david at 01map.net
> Tél: 04 67 45 60 27
> Entreprise: http://www.01map.net
> Perso: http://techer.pascal.free.fr/postgis/
> ----- Original Message -----
> From: strk at refractions.net
> To: PostGIS Development Discussion
> Sent: Monday, July 04, 2005 3:40 PM
> Subject: Re: [postgis-devel] ICONV autodetection (head branch)
> On Mon, Jul 04, 2005 at 03:30:17PM +0200, Jean David TECHER wrote:
> > No prob Sandro...I've already sent U my mail last week! Strange?
> > My patch is attached to this mail for win32
> First patch is USE_ICONV=0 forced, which shouldn't be needed anymore.
> copied from postgresql sourced.
> Alex, can you take a look at the latter ?
> --strk;
> > TECHER Jean David
> > 01MAP
> > Tél: 04 67 45 60 27
> > Sent: Monday, July 04, 2005 3:13 PM
> > Sorry Dave, I'm a bit slow.
> > Can we try to discuss one thing at time ?
> > Which patch did you apply ? Didn't postgis compile w/out patches ?
> > --strk;
> > On Mon, Jul 04, 2005 at 02:04:25PM +0200, Jean David TECHER wrote:
> > > Yes Master!!! :-)
> > > cvs checkout postgis
> > > I applied my patch for windows
> > > and let in postgis/Makefile.config.in
> > > USE_ICONV=@USE_ICONV@
> > > I got
> > > for configure
> > > SUMMARY
> > > HOST_OS: mingw32
> > > PGSQL: /c/PostgreSQL/8.0.3/bin/pg_config
> > > GEOS: /c/PostgreSQL/8.0.3/bin/geos-config
> > > PROJ: dir=/c/PostgreSQL/8.0.3/bin/..
> > > ICONV: 0
> > > PORTNAME: win32
> > > PREFIX: /usr/local
> > > EPREFIX: ${prefix}
> > > DOC: ${prefix}/share/doc
> > > DATA: ${prefix}/share/postgresql/contrib
> > > MAN: ${prefix}/man
> > > BIN: c:/PostgreSQL/8.0.3/bin
> > > EXT: c:/PostgreSQL/8.0.3/lib (\$$libdir)
> > > Hum....!!! The only problem is to be able to have lwpostgis.sql and spatial_ref_sys.sql in the same directory og PG SHAREDIR
> > > Not really a goog idea!!! It's better to let postgis-prefix=/usr/local by default
> > > I will copy *.sql done by postgis manually (*.sql + doc + man)
> > > ok thanks :-)
> > > However Sandro I think it will be a great idea to let for win32 Path_to_PosttGIS_library = $lidbir even if user give '--prefix=...' when he uses configure
> > > I mean for win32 it's better to have
> > > EXT = (\$$libdir)
> > > instead of
> > > EXT := ${exec_prefix}/$/libexec when we use configure
> > > So I will not have to replace EXT by libdir in lwpostgis.sql since PostgreSLQ doesn't support /c/ in path
> > > TECHER Jean David
> > > 01MAP
> > > Tél: 04 67 45 60 27
> > > Sent: Monday, July 04, 2005 11:48 AM
> > > Subject: [postgis-devel] ICONV autodetection (head branch)
> > > On Thu, Jun 30, 2005 at 10:36:11AM +0200, Jean David TECHER wrote:
> > > > Sorry for iconv I've had problem so I put USE_ICONV=0 in postgis/Makefile.config.in
> > > > Make and make install works fine!!!
> > > I've reworked iconv detection code to be more conservative.
> > > It should now be enabled only if the c library provide that functionality.
> > > (no external libiconv supported).
> > > This should remove the need of manually edit Makefile.config
> > > --strk;
> > > _______________________________________________
> > > postgis-devel mailing list
> > > postgis-devel at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
