[postgis-devel] postgresql sources dependency relief
Markus Schaber schabi at logix-tt.com
Thu Jun 2 01:32:54 PDT 2005
Hi, Alex,
alexbodn at 012.net.il wrote:
> a few days ago you have manifested interest in the patches i have submitted
> to postgis-cvs, to relief the build dependency on postgresql sources.
> since i got no response from your side, i would ask you for your opinion on
> the patches.
> posting your opinion on the list might enlarge the testers circle before the
> decision to apply the patches.
I  alreadyposted my comments at Tue, 31 May 2005 14:44:10 +0200, but
here it is again:
> Hi, Alex,
> alex bodnaru wrote:
>>> here is a diff you could use for jdbc2/Makefile, instead of the
>>> previous.
>>> i have tested it and works ok (i am using the Makefile.config
>>> functionality).
>>> i would be grateful if you could test with it for the special cases you
>>> know about.
> In my tests, it built the jar files and ran the tests without having a
> ../Makefile.config.
> Great work.
> As this patch seems to depend on those for the non-jdbc Makefiles, I
> will not commit it now, but I think it should be committed with the others.
>>> p.s. the moment we merge those changes, i can already send a new and
>>> slim debian package for postgis-1.1.
>>> current packages are at http://packages.qa.debian.org/p/postgis.html.
> Great!
> Markus
HTH,
Markus
