[postgis-devel] relief of dependency on postgresql sources
strk at refractions.net strk at refractions.net
Sat Jun 4 04:52:45 PDT 2005
On Sat, Jun 04, 2005 at 02:42:20PM +0300, alex bodnaru wrote:
> hi strk,
> good to see you back.
> thanks for uploading my work. just note, that jdbc2 will be broken until
> patched.
I'd leave this to Markus which maintains the jdbc2 code.
> needless to say, that the package builds and runs on a debian machine,
> with only the api headers installed.
> btw, if you have unstandard configuration, you could pass
> --with-config=[your installed pg_config full name] to autoconf, and i
> hope it will work for you. (if i really understand autoconf from this
> first time impact).
That is --with-pgsql, right ?
--strk;
> best regards,
> alex
> On Sat, 2005-06-04 at 12:17 +0200, strk at refractions.net wrote:
> > Alex, thank you for your work. I've committed your patch to easy
> > further testing (head branch).
> > The jdbc2/Makefile separated one is not there yet, Markus, could you
> > apply it yourself ?
> > I think next step should be having path names match the 1.0.1 layout
> > and to test with different pgsql versions/configurations. I have
> > no default installation of pgsql, if anyone does tests against
> > them would be highly appreciated.
> > --strk;
> > On Tue, May 31, 2005 at 02:44:10PM +0200, Markus Schaber wrote:
> > > Hi, Alex,
> > > alex bodnaru wrote:
> > > > here is a diff you could use for jdbc2/Makefile, instead of the
> > > > previous.
> > > > i have tested it and works ok (i am using the Makefile.config
> > > > functionality).
> > > > i would be grateful if you could test with it for the special cases you
> > > > know about.
> > > In my tests, it built the jar files and ran the tests without having a
> > > ../Makefile.config.
> > > Great work.
> > > As this patch seems to depend on those for the non-jdbc Makefiles, I
> > > will not commit it now, but I think it should be committed with the others.
> > > > p.s. the moment we merge those changes, i can already send a new and
> > > > slim debian package for postgis-1.1.
> > > > current packages are at http://packages.qa.debian.org/p/postgis.html.
> > > Great!
> > > Markus
> > > _______________________________________________
> > > postgis-devel mailing list
> > > postgis-devel at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
