[postgis-devel] invalid memory alloc request size
strk at refractions.net strk at refractions.net
Fri Jun 10 02:23:53 PDT 2005
Can you reproduce with any non-GEOS function ?
Does the problem show up with *all* GEOS functions ?
Did you try geosnoop() ?
--strk;
On Fri, Jun 10, 2005 at 11:12:34AM +0200, Markus Schaber wrote:
> Hi, Strk,
> I just retried it with a freshly CVS checked-out, compiled and installed
> PostGIS database, and I get the error.
> lwgeom_patched=# select isvalid('GEOMETRYCOLLECTION EMPTY'::geometry);
> ERROR:  invalid memory alloc request size 0
> Could this be some incompatibility betweeen my PostGIS and GEOS? Maybe I
> did manage to break my geos installation, or even my postmaster...
> Btw, using PostGIS 0.8 and 0.9, it works fine.
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
