[postgis-devel] GeomUnion Performance Info
strk at refractions.net strk at refractions.net
Sat Jun 25 00:40:03 PDT 2005
On Fri, Jun 24, 2005 at 03:38:56PM -0400, Bill Binko wrote:
> On Thu, 23 Jun 2005 strk at refractions.net wrote:
> > > It will take at least tomorrow to do that.  However, I'll aim for being
> > > complete before the weekend in case there's development to be done then.
> I'm sorry strk: my day job (you know the one with the pay check) has
> swamped me.  I will try to get to this this evening, but it might be
> tomorrow.
> Again: sorry!
No problem. I'm attacking the problem from another prospective
and Martin Davis suggested a way which actually runs about 3 times
faster.
For everyone interested, please compare these calls, which should
return the same result:
	memgeomunion(the_geom);
	buffer(collect(the_geom), 0);
Last version should be faster and not be affected by input order.
Graph is built once!
I think we can have geomunion() internally use the buffer(0) method,
which could be faster then the explicit buffer(collect()) call
in that should require less copies of data.
I'm experimenting this.
--strk;
