[postgis-devel] RC3 build/install script bugs
strk at refractions.net strk at refractions.net
Tue Mar 1 00:30:40 PST 2005
Thanks Rhys, I've fixed the lwpostgis.sql install rule
and the FLEX/YACC settings.
With the FLEX/YACC patch tough, you can't redefine them using
environemnt variables. The question is: why doesn't PGSQL define
them ?
--strk;
On Tue, Mar 01, 2005 at 12:03:38PM +1100, Rhys Ickeringill wrote:
> G'day All.
> Hope this is the right spot to post bugs. Just had a few little hitches
> building RC3
> Some system info in case it's pertinent:
> OS: Linux 2.4.29 (Slackware 10.1)
> postgreSQL: 7.4.7
> make: 3.8
> yacc: 1.9 (byacc)
> bison: 1.35
> flex: 2.5.4
> First the easy one - when a "make install DESTDIR=/tmp/pkg" is issued in
> postgis-1.1.0-rc3, I end up with a file 'share' in /tmp/pkg/usr/local/pgsql.
> The file is actually (as I'm sure you've guessed) 'lwpostgis.sql'. This
> error only shows up if the $DESTDIR/usr/local/share doesn't already exist.
> Changing the action taken for target 'install-lwgeom-scripts' in
> postgis-1.1.0-rc3/lwgeom/Makefile from
> $(INSTALL_DATA) lwpostgis.sql $(DESTDIR)$(datadir)
> to
> $(INSTALL_DATA) lwpostgis.sql $(DESTDIR)$(datadir)/lwpostgis.sql
> seems do the 'right' thing for me in all situations.
> The next one seems to have been reported for RC2, but still exists in RC3.
> When a "make" is issued in postgis-1.1.0-rc3, the make fails:
> gcc -O2 -pipe -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-decl
> arations -g -fexceptions -fPIC -DUSE_VERSION=74 -DPOSTGIS_LIB_VERSION='"1.0.
> 0RC3"' -DPOSTGIS_SCRIPTS_VERSION='"0.2.0"' -DPOSTGIS_BUILD_DATE='"2005-03-01
> 00:21:01"' -I/usr/local/include -DUSE_GEOS -I/usr/local/include -DUSE_PROJ -
> I/usr/local/include -DAUTOCACHE_BBOX=1 -DUSE_STATS -fpic -I/usr/src/postgres
> ql-7.4.7/contrib/postgis-1.0.0-rc3/../../src/include -D_GNU_SOURCE -c -o
> wktparse.tab.o wktparse.tab.c
> Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
> make[1]: Plwg_parse_yy: Command not found
> make[1]: [lex.yy.c] Error 127 (ignored)
> lex.yy.o lex.yy.c
> gcc: lex.yy.c: No such file or directory
> gcc: no input files
> make[1]: *** [lex.yy.o] Error 1
> make[1]: Leaving directory
> `/usr/src/postgresql-7.4.7/contrib/postgis-1.0.0-rc3/lwgeom'
> make: *** [liblwgeom] Error 2
> Apparently this error is caused by $FLEX variable being incorrecly defined
> in postgis-1.0.0-rc3/lwgeom/Makefile. From what I can tell, the $FLEX
> variable comes from postgis-1.0.0-rc3/Makefile.config, which includes
> 'Makefile.global' from the directory $PGSQL_SRC (the postgreSQL source tree
> root). In my $PGSQL_SRC/Makefile.global I have the line...
> FLEX =
> ...which means the line in postgis-1.0.0-rc3/Makefile.config...
> FLEX ?= flex
> ...keeps the definition of $FLEX from $PGSQL_SRC/Makefile.global (I assuming
> that's what the ?= operator means - I'm no makefile expert)
> To fix this for my specific case was trivial. But to continue leveraging the
> info collected by the postgres configure script (I'm guessing this is why
> $PGSQL_SRC/Makefile.global is included) perhaps it is worth replacing FLEX
> ?= flex with something like:
> ifeq ($(strip $(FLEX)),)
>     FLEX = flex
> endif
> Perhaps it would be also worthwhile to do the same for $YACC too.
> Regards,
> Rhys
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
