[postgis-devel] RC3 build/install script bugs
strk at refractions.net strk at refractions.net
Thu Mar 3 02:20:51 PST 2005
I've added generated files into CVS.
These are: lex.yy.c wktparse.tab.c wktparse.tab.h
``make clean'' won't get rid of them.
Changes will be notified by cvs client (removed from .cvsignore).
I've tested this on a pretty old freebsd and have no problem.
What about a big round-test-before-release ?
--strk;
On Wed, Mar 02, 2005 at 11:10:42AM +0100, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net schrieb:
> >>>From PGSQL's configure script:
> >>*** Without Flex you will not be able to build PostgreSQL from CVS or
> >>*** change any of the scanner definition files. You can obtain Flex from
> >>*** a GNU mirror site. (If you are using the official distribution of
> >>*** PostgreSQL then you do not need to worry about this because the Flex
> >>*** output is pre-generated.)
> >>Hence my build went ahead anyway because I was using the official
> >>distribution.
> > What do people think about doing the same ?
> I think most people will not change the parser files, so would vote +1
> on this. Easying build requirements is always a good idea. Maybe it even
> makes sense to have them in CVS, as they change rather seldomly.
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
