[postgis-devel] RC3 build/install script bugs
Markus Schaber schabi at logix-tt.com
Thu Mar 3 03:07:51 PST 2005
Hi, strk,
strk at refractions.net schrieb:
> I've added generated files into CVS.
> These are: lex.yy.c wktparse.tab.c wktparse.tab.h
> ``make clean'' won't get rid of them.
> Changes will be notified by cvs client (removed from .cvsignore).
Fine.
What do you think about a "make distclean", "make maintainerclean" or
"make mrproper" (there's no common name?) that helps deleting even those
files?
> I've tested this on a pretty old freebsd and have no problem.
> What about a big round-test-before-release ?
Compiles and installs fine here, and also passes all jdbc2 regression tests.
Markus
Markus Schaber | Dipl. Informatiker | Software Development GIS
Fight against software patents in EU! http://ffii.org/
                                      http://nosoftwarepatents.org/
