[postgis-devel] WKB problems on Linux AMD64
strk at refractions.net strk at refractions.net
Sun Mar 6 22:50:43 PST 2005
On Sun, Mar 06, 2005 at 11:19:35PM +0100, clozano at quavantis.com wrote:
> Hi,
> I am having problems importing data into postgis running on a Suse 9.2
> x86_64 (amd64) when using WKB format data.
You mean binary WKB, right ?
Do you get an error message, a memory fault or just "wrong" imports ?
Did you get any warning at compile time ?
Does 0.9.1 also give you problems with WKB ?
--strk;
> I've built versions 0.9.1, 1.0.0rc2 and 1.0.0rc3 satisfactorily on both
> Suse 9.2 i686 and x86_64, everything works fine on the 32 bit box and
> everything, with the exception of WKB, works on the 64 bit box. I'm
> running Postgres 8.0.1 on both boxes, 32 and 64bit respectively - same
> linux distro.
> Has anyone come across this problem? Could anyone give me some pointers as
> to what may be the problem/solution?
> Salutacions - Un Saludo - Regards,
> Carlos Lozano Diez
>  Quavantis - mWorld Company
>  Mobile & Wireless Solutions
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
