[postgis-devel] More JDBC2 fun....
Markus Schaber markus at schabi.de
Mon Mar 21 06:48:51 PST 2005
Hi, Mark,
Mark Cave-Ayland schrieb:
> Just to let you know I've just compiled up some Win32 binaries for RC4 and
> was quite surprised to find that this time around, the Makefile compiled
> correctly under MingW with CPSEP set to : and not ; (!) I don't have a clue
> why this is now different from RC3, but thought I should document it on the
> lists.
Strange. Did you use a different jdk?
> I also had to make one minor modification to the Makefile in order to get
> the offline tests to run correctly after compilation:
> 	RUNCP=$(POSTGIS_BUILD_CLASSPATH)$(CPSEP)./postgis.jar
> Without the ./ in front of postgis.jar, the JAR file could not be found when
> launching the offline tests.
It works for me, and I don't think that this change would break another jre.
But I learned to triple-check before I check this change in. Alex, could
you have a look at it? Strk, and everyone else, does this work for you?
Markus
