[postgis-devel] Incorrect proj parameters in spatial_ref_sys?
Paul Ramsey pramsey at refractions.net
Sat Mar 26 17:06:43 PST 2005
I think you're confused... ESRI and EPSG agree that 2964 is
NAD_1927_Alaska_Albers_Feet, not metres. EPSG description: "Cartesian 2D
CS.  Axes: easting, northing (X,Y). Orientations: east, north.  UoM: ftUS."
Gary Sherman wrote:
> It appears there may be an incorrect parameter in the spatial_ref_sys table
> for some projections.
> For example, SRID 2964 contains the proj4 parameter:
> +to_meter=0.3048006096012192
> When creating a layer in SRID 2964 from WGS84 (SRID 4326) using the transform
> function, the coordinates are incorrect. It appears that each coordinate is
> being divided by the to_meter value during transformation. This results in a
> y-shift on the order of 2.8 million meters and approximately a 500K meter
> x-shift. The units of the Alaska Albers projection (2964) are meters.
> Dropping the to_meter parameter from the spatial_ref_sys entry results in a
> correct transform.
> This same behavior was noticed using ogr2ogr to transform from a geographic
> shapefile to Alaska Albers.
> SQL used to create the transformed table:
>   create table waypoints_alb as select gid, name, transform(the_geom,2964)
>   from waypoints_geo;
> Comments -- or am I confused...
> -gary
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
