[postgis-devel] More JDBC2 fun....
alexbodn at 012.net.il alexbodn at 012.net.il
Tue Mar 29 08:32:02 PST 2005
it seems i have missed something. i will try it again.
btw:
do you use the debian packages?
regards,
alex
> Hi, Mark,
> Mark Cave-Ayland schrieb:
> >>>I also had to make one minor modification to the Makefile in
> order to
> >>>get the offline tests to run correctly after compilation:
> >>>	RUNCP=$(POSTGIS_BUILD_CLASSPATH)$(CPSEP)./postgis.jar
> >>>Without the ./ in front of postgis.jar, the JAR file could not
> be
> >>>found when launching the offline tests.
> >>It works for me, and I don't think that this change would
> >>break another jre.
> >>But I learned to triple-check before I check this change in.
> >>Alex, could you have a look at it? Strk, and everyone else,
> >>does this work for you?
> > The reason I resurrected this thread is that the same setup
> described above
> > was used to successfully compile the JDBC2 driver for RC5 on the
> first> attempt, i.e. CSEP set to : and the ./ in front of
> postgis.jar. Anyone else
> > have any experience with this?
> As there's no feedback up to now, I'll check the change into CVS.
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
