[postgis-devel] More JDBC2 fun....
Markus Schaber markus at schabi.de
Tue Mar 29 08:51:02 PST 2005
Hi, Alex,
alexbodn at 012.net.il schrieb:
> it seems i have missed something. i will try it again.
It is a one-line change in the makefile, a ./ is added:
RUNCP=$(POSTGIS_BUILD_CLASSPATH)$(CPSEP)./postgis.jar
> do you use the debian packages?
Not in production yet, but I installed them on a testbed machine, and
they seemed to work fine. My main developer machine uses hand-compiled
PostGIS because I have several PostGIS versions installed in parallel.
Do you have apt/sources.list entries for postgis?
What about uploading your packages to experimental repository of debian
(or maybe even into unstable so we could get postgis into sarge before
it is "stabilized")?
Markus
