[postgis-devel] RE: [postgis-users] pgsql2shp changing case of fieldnames
Obe, Regina DND\MIS robe.dnd at cityofboston.gov
Fri May 13 07:45:05 PDT 2005
Hi strk,
It is Regina.  I guess we should check or give a warning.  I tried a test
with outputing a table with one field named label and another "LABEL" and
then opened it in Arc Explorer.  It opens in Arc Explorer fine, but when you
use the information tool it only shows one of the "label" fields and kicks
the other one out.
I tried a DBF ODBC driver and got similar behavior.
Thanks,
Regina
-----Original Message-----
From: 'strk at refractions.net' [mailto:strk at refractions.net]
Sent: Friday, May 13, 2005 10:09 AM
To: Obe, Regina DNDMIS
Cc: postgis-devel at postgis.refractions.net
Subject: Re: [postgis-users] pgsql2shp changing case of fieldnames
Thanks Obe (or Regina?).
I've applied your patch, but I'm not sure about something: would a DBF be
legal if it contains attributes like 'LABEL' and 'label' in the same file ?
This would be a valid postgresql table, but is this true for .dbf ?
In case it isn't we should do a case-insensitive match where
we check this (around line 2650). I left a TODO there:
      * TODO: check out if should be case-insensitive
      * here since we might be running in -k mode
--strk;
On Fri, May 13, 2005 at 08:41:54AM -0400, Obe, Regina     DNDMIS wrote:
> I was working off of the cvs hourly build snapshot from the postgis
> site. Unfortunately I'm behind a firewall so don't think I can hit a cvs.
> I made a diff patch.  Attached is the file.  I hope I did it right.
> Thanks,
> Regina
> Sent: Friday, May 13, 2005 3:26 AM
> On Thu, May 12, 2005 at 08:27:57AM -0400, Obe, Regina     DNDMIS wrote:
> > I've made the change in my copy and it seems to work okay so far.
> > I'm
> > going to test it a little more.  So I guess I just need to know how to
> > send you the patch.
> Are you working on a CVS snapshot ?
> If so use cvs diff and send me the output (should be small). If you
> have problems with that just send me the whole pgsql2shp.c file and
> I'll check the changes myself. Thanks.
> --strk;
> > Thanks,
> > Regina
> > From: strk at refractions.net [mailto:strk at refractions.net]
> > Sent: Tuesday, May 10, 2005 2:42 PM
> > Cc: 'PostGIS Users Discussion'
> > I've added the request in the HEAD branch TODO list.
> > If you will do it yourself sooner then us
> > we'll accept patches. Let me know if you plan to do it
> > and feel free to ask any info you might need for that.
> > --strk;
> > On Mon, May 09, 2005 at 04:02:46PM -0400, Obe, Regina     DNDMIS wrote:
> > > The old one I had was dated sometime in 2003 and was compiled
> > > under cygwin, but it still seemed to work when I upgraded to 8.0.
> > > I think a -k switch would be best.
> > > The older version preserved the case that was in postgres so for
> > > situations where we needed UPPERCASE (standard shp behavior) we
> > > had to create views that had the fields upper cased and dumped
> > > those out; so this new version irradicates that need.  There are
> > > some situations where it is convenient to keep the same case as
> > > postgres - e.g. it makes it easier to swap out a postgis layer
> > > with a shape layer where postgis is not feasible for a particular
> > > environment.  I'm assuming mapserver is still case sensitive with
> > > field names in templates.
> > > Sent: Monday, May 09, 2005 11:26 AM
> > > To: 'PostGIS Users Discussion'
> > > On Mon, May 09, 2005 at 10:18:52AM -0400, Obe, Regina     DNDMIS
wrote:
> > > > I noticed the 3/31/05 build of pgsql2shp I have now
> > > > automatically
> > > > forces the output field names to upper case which normally would
> > > > be a good thing. Unfortunately I've got some old mapserver maps
> > > > that rely on the field names in the dbf being in lowercase.  Is
> > > > there anyway to reverse this behavior e.g. with a switch or
> > > > something of that sort so that I don't have to revert back to the
> > > > older version of pgsql2shp?
> > > > Thanks,
> > > > Regina
> > > Which version of pgsql2shp doesn't do that ?
> > > I guess we can revert the change back ... or add a -k switch to it
> > > as
> > > well.
> > > Does anyone see a problem with this ?
> > > --strk;
> > > _______________________________________________
> > > postgis-users mailing list postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
