[postgis-devel] RE: [postgis-users] pgsql2shp changing case of fieldnames
Obe, Regina DND\MIS robe.dnd at cityofboston.gov
Fri May 13 09:21:48 PDT 2005
I think renaming is good and warning as well that we are renaming is better.
-----Original Message-----
From: strk at refractions.net [mailto:strk at refractions.net]
Sent: Friday, May 13, 2005 10:51 AM
To: Obe, Regina DNDMIS
Cc: postgis-devel at postgis.refractions.net
Subject: Re: [postgis-users] pgsql2shp changing case of fieldnames
On Fri, May 13, 2005 at 10:45:05AM -0400, Obe, Regina     DNDMIS wrote:
> Hi strk,
> It is Regina.  I guess we should check or give a warning.  I tried a
> test with outputing a table with one field named label and another
> "LABEL" and then opened it in Arc Explorer.  It opens in Arc Explorer
> fine, but when you use the information tool it only shows one of the
> "label" fields and kicks the other one out.
> I tried a DBF ODBC driver and got similar behavior.
So, are you suggesting pgsql2shp issueing a warning when caseless equality
of 2 fields is detected with -k ?
(it renames duplicated field names w/out -k)
--strk;
> Thanks,
> Regina
> From: 'strk at refractions.net' [mailto:strk at refractions.net]
> Sent: Friday, May 13, 2005 10:09 AM
> Thanks Obe (or Regina?).
> I've applied your patch, but I'm not sure about something: would a DBF
> be legal if it contains attributes like 'LABEL' and 'label' in the
> same file ? This would be a valid postgresql table, but is this true
> for .dbf ?
> In case it isn't we should do a case-insensitive match where
> we check this (around line 2650). I left a TODO there:
>       * TODO: check out if should be case-insensitive
>       * here since we might be running in -k mode
> --strk;
> On Fri, May 13, 2005 at 08:41:54AM -0400, Obe, Regina     DNDMIS wrote:
> > I was working off of the cvs hourly build snapshot from the postgis
> > site. Unfortunately I'm behind a firewall so don't think I can hit a
cvs.
> > I made a diff patch.  Attached is the file.  I hope I did it right.
> > Thanks,
> > Regina
> > Sent: Friday, May 13, 2005 3:26 AM
> > On Thu, May 12, 2005 at 08:27:57AM -0400, Obe, Regina     DNDMIS wrote:
> > > I've made the change in my copy and it seems to work okay so far.
> > > I'm
> > > going to test it a little more.  So I guess I just need to know how to
> > > send you the patch.
> > Are you working on a CVS snapshot ?
> > If so use cvs diff and send me the output (should be small). If you
> > have problems with that just send me the whole pgsql2shp.c file and
> > I'll check the changes myself. Thanks.
> > --strk;
> > > Thanks,
> > > Regina
> > > Sent: Tuesday, May 10, 2005 2:42 PM
> > > Cc: 'PostGIS Users Discussion'
> > > I've added the request in the HEAD branch TODO list.
> > > If you will do it yourself sooner then us
> > > we'll accept patches. Let me know if you plan to do it and feel
> > > free to ask any info you might need for that.
> > > --strk;
> > > On Mon, May 09, 2005 at 04:02:46PM -0400, Obe, Regina     DNDMIS
wrote:
> > > > The old one I had was dated sometime in 2003 and was compiled
> > > > under cygwin, but it still seemed to work when I upgraded to 8.0.
> > > > I think a -k switch would be best.
> > > > The older version preserved the case that was in postgres so for
> > > > situations where we needed UPPERCASE (standard shp behavior) we
> > > > had to create views that had the fields upper cased and dumped
> > > > those out; so this new version irradicates that need.  There are
> > > > some situations where it is convenient to keep the same case as
> > > > postgres - e.g. it makes it easier to swap out a postgis layer
> > > > with a shape layer where postgis is not feasible for a particular
> > > > environment.  I'm assuming mapserver is still case sensitive with
> > > > field names in templates.
> > > > Sent: Monday, May 09, 2005 11:26 AM
> > > > To: 'PostGIS Users Discussion'
> > > > fieldnames
> > > > On Mon, May 09, 2005 at 10:18:52AM -0400, Obe, Regina     DNDMIS
> wrote:
> > > > > I noticed the 3/31/05 build of pgsql2shp I have now
> > > > > automatically
> > > > > forces the output field names to upper case which normally would
> > > > > be a good thing. Unfortunately I've got some old mapserver maps
> > > > > that rely on the field names in the dbf being in lowercase.  Is
> > > > > there anyway to reverse this behavior e.g. with a switch or
> > > > > something of that sort so that I don't have to revert back to the
> > > > > older version of pgsql2shp?
> > > > > Thanks,
> > > > > Regina
> > > > Which version of pgsql2shp doesn't do that ?
> > > > I guess we can revert the change back ... or add a -k switch to
> > > > it as well.
> > > > Does anyone see a problem with this ?
> > > > --strk;
> > > > _______________________________________________
> > > > postgis-users mailing list postgis-users at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
