[postgis-devel] autoconfiguration for version 1.1.0CVS
strk at refractions.net strk at refractions.net
Tue May 17 09:16:53 PDT 2005
>From an initial work I did on this approach I found myself forced
into pre-costituted rules I didn't like to delegate to the
pgsql source tree. In case we can simply use the *build* of
the shared library (with no install) I agree on using it.
The pgxs stuff is at an initial stage and has been designed for
small extensions. I don't think postgis is such a small extension.
I do see the "wasted" duplication effort of maintaining cross-arch
build scripts in postgis when this is done in postgresql alread
but did not handle to find an elegant solution to the "locking"
problem.
The approach suggested by Mark is the one I liked the most:
use pgsql sources if USE_VERSION<800 or use pgxs otherwise.
Any help in implementing it w/out loosing the flexibility
of deciding *where* to install the shared library is welcome.
Note that Makefile.shlib (pgsql-src) and Makefile.pgxs (pgxs)
are different, and need different threatment. My initial attempt
was at providing a parametrized include in lwgeom/Makefile sourcing
a local Makefile.shlib or the pgxs one. In that case we should be
reproducing the pgxs mechanism locally.
Again. Any contribution is welcome. Just let's try to keep things
simple. My question about which archs are people running postgis
on was bound to knowing how large is the required archset and evaluate
the required effort to support them all. Currently postgis build
has been tested on GNU/Linux, Darwin and Mingw.
About SONAME: can you tell me more about the lack of it ?
What is it ? A variable for Makefile.pgxs ?
--strk;
On Tue, May 17, 2005 at 04:28:59PM +0300, alexbodn at 012.net.il wrote:
> hello friends,
> though the autoconfiguration of postgis should use only the publicly available postgresql
> information, i think we went too far with dropping usage of Makefile.shlib.
> this file is a collection of information needed to make a shared library in the postgresql
> environment, as is stated in it's header.
> although i agree it could be splitted in small files, each for a specific architecture, and
> included with the postgresql api, this information should be undoubtely used in the
> process of building postgis, which is a shlib itself.
> please also note, that newer postgresql is only adding new architectures to this file, but
> it doesn't make other significant changes.
> at the moment, the linux postgis library is lacking the SONAME, and this is the situation
> with other unices, too.
> i would kindly ask you to reinclude Makefile.shlib dependency in postgresql, and in the
> most extreme situation, please include a separate Makefile.shlib for each supported
> postgresql branch.
> best regards,
> alex
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
