[postgis-devel] autoconfiguration for version 1.1.0CVS
strk at refractions.net strk at refractions.net
Wed May 18 09:54:55 PDT 2005
Again. Every contribution is higly appreciated.
If you find it easy and you have time please send a patch.
--strk;
On Wed, May 18, 2005 at 04:04:40AM +0300, alex bodnaru wrote:
> hi strk
> On Tue, 2005-05-17 at 18:16 +0200, strk at refractions.net wrote:
> > >From an initial work I did on this approach I found myself forced
> > into pre-costituted rules I didn't like to delegate to the
> > pgsql source tree. In case we can simply use the *build* of
> > the shared library (with no install) I agree on using it.
> the build part is the reason for my message, but after i took a look,
> the install part is totally parametric, and i see no problem with it,
> too.
> > The pgxs stuff is at an initial stage and has been designed for
> > small extensions. I don't think postgis is such a small extension.
> > I do see the "wasted" duplication effort of maintaining cross-arch
> > build scripts in postgis when this is done in postgresql alread
> > but did not handle to find an elegant solution to the "locking"
> > problem.
> i beg your pardon, but i don't quite understand what the locking problem
> is.
> > The approach suggested by Mark is the one I liked the most:
> > use pgsql sources if USE_VERSION<800 or use pgxs otherwise.
> you have just stated that pgxs is made for a too small postgresql
> extension.
> > Any help in implementing it w/out loosing the flexibility
> > of deciding *where* to install the shared library is welcome.
> as i wrote above, the shared libraries installation is not mandatory in
> Makefile.shlib, and if you decide to use it, the files will go to a
> location provided in $libdir. this has a value provided by pg_config.
> > Note that Makefile.shlib (pgsql-src) and Makefile.pgxs (pgxs)
> > are different, and need different threatment. My initial attempt
> > was at providing a parametrized include in lwgeom/Makefile sourcing
> > a local Makefile.shlib or the pgxs one. In that case we should be
> > reproducing the pgxs mechanism locally.
> it seems, that there are no significant differences between
> Makefile.shlib versions (except architecture additions), but in the
> worst case, all could be provided in Makefile.shlib.$USE_VERSION for
> about 30 kb on disk. sory to have omitted Makefile.pgxs in this
> sentence.
> > Again. Any contribution is welcome. Just let's try to keep things
> > simple. My question about which archs are people running postgis
> > on was bound to knowing how large is the required archset and evaluate
> > the required effort to support them all. Currently postgis build
> > has been tested on GNU/Linux, Darwin and Mingw.
> keep your mind free. maybe there is a happy user of an exotic
> architecture not attending the list?
> > About SONAME: can you tell me more about the lack of it ?
> > What is it ? A variable for Makefile.pgxs ?
> it is a much more general issue. please see
> http://wiki.linuxquestions.org/wiki/Library-related_Commands_and_Files#soname
> Makefile.shlib does support it.
> alex
> > --strk;
> > On Tue, May 17, 2005 at 04:28:59PM +0300, alexbodn at 012.net.il wrote:
> > > hello friends,
> > > though the autoconfiguration of postgis should use only the publicly available postgresql
> > > information, i think we went too far with dropping usage of Makefile.shlib.
> > > this file is a collection of information needed to make a shared library in the postgresql
> > > environment, as is stated in it's header.
> > > although i agree it could be splitted in small files, each for a specific architecture, and
> > > included with the postgresql api, this information should be undoubtely used in the
> > > process of building postgis, which is a shlib itself.
> > > please also note, that newer postgresql is only adding new architectures to this file, but
> > > it doesn't make other significant changes.
> > > at the moment, the linux postgis library is lacking the SONAME, and this is the situation
> > > with other unices, too.
> > > i would kindly ask you to reinclude Makefile.shlib dependency in postgresql, and in the
> > > most extreme situation, please include a separate Makefile.shlib for each supported
> > > postgresql branch.
> > > best regards,
> > > alex
> > > _______________________________________________
> > > postgis-devel mailing list
> > > postgis-devel at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
