[postgis-devel] relief of dependency on postgresql sources
Markus Schaber schabi at logix-tt.com
Tue May 31 05:44:10 PDT 2005
Hi, Alex,
alex bodnaru wrote:
> here is a diff you could use for jdbc2/Makefile, instead of the
> previous.
> i have tested it and works ok (i am using the Makefile.config
> functionality).
> i would be grateful if you could test with it for the special cases you
> know about.
In my tests, it built the jar files and ran the tests without having a
../Makefile.config.
Great work.
As this patch seems to depend on those for the non-jdbc Makefiles, I
will not commit it now, but I think it should be committed with the others.
> p.s. the moment we merge those changes, i can already send a new and
> slim debian package for postgis-1.1.
> current packages are at http://packages.qa.debian.org/p/postgis.html.
Great!
Markus
