[postgis-devel] FreeBSD broke with autoconf-based build
strk at refractions.net strk at refractions.net
Tue Nov 1 03:32:41 PST 2005
I'm having troubles building postgis HEAD on freebsd
using the new autoconf-based scripts.
The Makefile.shlib file copied by pgsql sources
adds a -Bforcearchive flag to LINK.shared with
arch is freebsd, but the flag seems to be
unsupported (this is from 7.2.1 to 8.0.0)
Weird enough PostgreSQL build works fine
(no -Bforcearchive flag used)
If I remove the -Bforcearchive flag from Makefile.shlib
everything seems to work fine.
I suppose (but didn't test) that this would also fail with
pgxs.  Are there freebsd users around to test this ?
--strk;
