[postgis-devel] shp2pgsql and shapefiles without vertices
strk at refractions.net strk at refractions.net
Tue Nov 1 03:53:54 PST 2005
Committed in 1.0.
--strk;
On Tue, Nov 01, 2005 at 12:47:13PM +0100, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net schrieb:
> > Note that intended behaviour has always been _a_bort if shapefile
> > contains ONLY null geometries. The check has always been there, but
> > it contained a bug: return code from SHPReadObject() was checked
> > for NULL (error condition) rather then for nVertices()==0
> > (see revision 1.88.2.5).
> Oh, then this is a longtime-unnoticed bug that turned into a feature for
> the users :-)
> > Rather then drop the check (which require double scan of the
> > shapefile, and also leaked memory) I just plugged the memory
> > leak and fixed the bug.
> > I've implemented the 3-option switch you suggest in HEAD.
> > 	-N insert, -Ni
> > 	-N skip, -Ns
> > 	-N abort, -Na
> Thanks.
> > As for 1.0 I'd just drop the first scan as a whole, to fix
> > the back-compatibility issue. Comments ?
> Sounds good.
> Thanks,
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
