[postgis-devel] Transform() PROJ4 cache patch
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Nov 4 01:06:41 PST 2005
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: 03 November 2005 09:45
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Transform() PROJ4 cache patch
> Another comment, why use a separate file ?
> I think it would make maintainence harder.
> --strk;
Hi strk,
It was really an attempt to try and make the code a bit easier to follow
when looking at the transform() function. If you're happy that it's still
readable with everything being in one file then I'll resubmit the (minor)
mods I made in the second patch back in the format of the first.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
