[postgis-devel] Memory alignment issues (was: crash (somehow) resolved)
strk at refractions.net strk at refractions.net
Mon Nov 14 08:21:49 PST 2005
On Mon, Nov 14, 2005 at 09:16:33AM -0700, Michael Fuhr wrote:
> On Mon, Nov 14, 2005 at 10:04:30AM +0100, strk at refractions.net wrote:
> > Please retry after update, I've changed the deserialization functions to
> > always copy the bounding box (if present). Previous behaviour was an unsafe
> > cast.
> That fixes the crash I reported -- thanks.  Are there any other
> queries I should try?
If all regression tests pass successfully on the 1.0 branch
you might try the HEAD branch - it uses autoconf-based
configuration which would be another thing to test.
Thank you very much.
--strk;
