[postgis-devel] Memory alignment issues (was: crash (somehow)resolved)
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Nov 16 01:09:19 PST 2005
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Michael Fuhr
> Sent: 15 November 2005 20:21
> To: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] Memory alignment issues (was:
(cut)
> Regression tests passed for both the 1.0 branch and HEAD with
> the exception of the differences below.  The first is due to
> the output being "Infinity" instead of "inf"; the second
> appears to be due to slight differences in floating-point
> calculations; the third is a NOTICE message that isn't in the
> expected output.
Hi Michael,
Thanks for doing this! Is this something that you can easily re-run? I'm
getting to the point where I'm nearly ready to commit my transform() caching
patch to CVS HEAD and due to the nature of the code, it is likely I may have
made some alighment errors somewhere :)
Many thanks,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
