[postgis-devel] Memory alignment issues (was: crash(somehow)resolved)
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Nov 16 08:32:18 PST 2005
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Michael Fuhr
> Sent: 16 November 2005 16:00
> To: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] Memory alignment issues (was:
(cut)
> I can rebuild and run tests pretty easily, so if you add new
> ones I'll check them out.  Is there a list that automatically
> receives commit messages or should I just watch for
> announcements in postgis-devel?
Hi Michael,
As far as I know there isn't a commit message list - I'll announce on
postgis-devel when I commit the new code which should be over the next few
days. It may be that I need to post some example scripts if the regression
tests don't yet cover the transform function :)
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
