[postgis-devel] Memory alignment issues(was:crash(somehow)resolved)
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Mon Nov 21 04:10:06 PST 2005
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Michael Fuhr
> Sent: 18 November 2005 18:09
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Memory alignment
(cut)
> Looks good on Solaris 9/sparc with PostgreSQL 8.0.4.  Regression
> tests pass, aside from the trivial differences I noted earlier;
> transform() no longer crashes, and it gives the same results as
> the 1.0 branch on a sample data set but about 35 times faster.
> Michael Fuhr
Hi Michael,
Brilliant. Thanks very much for testing this.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
