[postgis-devel] more fun on Ultrasparc, unfortunately...
strk at refractions.net strk at refractions.net
Wed Nov 30 08:59:05 PST 2005
Thanks very much. Included in 1.0 and HEAD branches.
--strk;
On Wed, Nov 30, 2005 at 05:21:49PM +0100, Alex Mayrhofer wrote:
> strk at refractions.net wrote:
> >Thank you.
> >Note that you don't need to provide separate scripts for HEAD,
> >two of the three you produce for 1.0 are enough.
> Here we are.
> In case you need a disclaimer to include them: I declare that you may use
> those files however you see fit.
> cheers
> alex
> 0|EMPTY
> 1|SRID=32633;POINT(574600 5316780)
> 2|SRID=32633;POINT(574600 5316780)
> 3|SRID=32633;POINT(574600 5316780)
> 4|SRID=32633;LINESTRING(574600 5316780,573140 5427940)
> 5|SRID=32633;LINESTRING(574600 5316780,573140 5427940)
> 6|16.00000000|48.00000000
> ERROR:  Input geometry has unknown (-1) SRID
> 8|SRID=4326;POINT(0 0)
> #!/bin/sh
> if [ -z "$TMPDIR" ]; then
> 	TMPDIR=/tmp
> fi
> OUTFILE="${TMPDIR}/regress_proj_out$$"
> echo "Running PROJ Regression Test..."
> echo "Output file is: '${OUTFILE}'"
> echo
> echo "       expected:'<'     obtained:'>'"
> echo
> DB=postgis_reg
> createdb $DB > /dev/null
> createlang plpgsql $DB > /dev/null
> psql -f ../lwpostgis.sql $DB > /dev/null 2>&1
> psql -tA < regress_proj.sql $DB 2>&1 | grep -v INSERT > "${OUTFILE}"
> diff regress_proj_expected "${OUTFILE}"
> sleep 1
> dropdb $DB > /dev/null
> -- some transform() regression
> -- prime spatial_ref_sys table with two projections
> --- EPSG 32633 : WGS 84 / UTM zone 33N
> INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (32633,'EPSG',32633,'PROJCS["WGS 84 / UTM zone 33N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",15],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32633"]]','+proj=utm +zone=33 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ');
> --- EPSG 4326 : WGS 84
> INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (4326,'EPSG',4326,'GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]','+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ');
> --- test #0: NULL values
> SELECT 0,coalesce(AsText(transform(NULL, 32633)),'EMPTY');
> --- test #1: a simple projection
> SELECT 1,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;POINT(16 48)'),32633),10));
> --- test #2: same in 3D
> SELECT 2,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;POINT(16 48 171)'),32633),10));
> --- test #3: same in 4D
> SELECT 3,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;POINT(16 48 171 -500)'),32633),10));
> --- test #4: LINESTRING projection, 2 points
> SELECT 4,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;LINESTRING(16 48, 16 49)'),32633),10));
> --- test #5: LINESTRING projection, 2 points, 4D
> SELECT 5,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;LINESTRING(16 48 0 0, 16 49 0 0)'),32633),10));
> --- test #6: re-projecting a projected value
> SELECT 6,round(X(transform(transform(GeomFromEWKT('SRID=4326;POINT(16 48)'),32633), 4326))::numeric,8),round(Y(transform(transform(GeomFromEWKT('SRID=4326;POINT(16 48)'),32633), 4326))::numeric,8);
> --- test #7: Should yield an error since input SRID is unknown
> SELECT transform(GeomFromEWKT('SRID=-1;POINT(0 0)'),4326);
> --- test #8: Transforming to same SRID
> SELECT 8,AsEWKT(transform(GeomFromEWKT('SRID=4326;POINT(0 0)'),4326));
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for open standards
  X     No HTML/RTF in email
 / \    No M$ Word docs in email
