[postgis-devel] Sparc 64bit problems
strk at refractions.net
Fri Oct 14 05:53:08 PDT 2005
Stephen, the first step would be reducing query complexity
to find out where the problem really is.
One of your query doesn't involve GEOS, so I'd drop geos
as the first thing. This is the AsText(GeometryN()) query.
Would you try removing the AsText part so we're left
with the GeometryN and canonical output functions only ?
--strk;
On Fri, Oct 14, 2005 at 10:04:21AM +1300, Stephen Campbell wrote:
> Having a few problems with postgis on sparcv9 architecture (64bit)...
> I'm not sure if I should have posted this to user or developer but it look like a problem with either gcc-4.0.2 or the code on sparcv9 so I post it here.
> Builds are of : postgresql-8.0.4 postgis-cvs geos-2.1.4 proj-4.4.9
> (all the regressions pass on the 64bit postgresql).
> - 32bit install built by gcc-3.3.3 using Suns assembler and linker
> - 64bit install built by gcc-4.0.2 using Suns assembler and linker
> Running the ogc_test_suite on a sparcstation5 (32bit) and Sun-Fire V480 (64bit)
> In both there is a second "buildings" from the T1 query presumable due to the point and polygon representations (position & footprint columns) in the buildings table, so I've adjusted for that in the "correct" reference output (runs are with query echo on)...
> Below under "GOOD (sparcv7)" and "NOT SO GOOD(sparcv9)" are edited diffs against the constructed "correct" reference output.
> Any ideas?, cheers, Stephen.
> GOOD (sparcv7):
> The 32bit (sparcv7) build just has a couple of polygon strings that start at different points, which I presume is ok? There a diff-u (1 space indented) with some trailing context edited out and the polygon string padded to make it easier to see...
> --- 2_queries.correct 2005-10-13 12:09:05.459992000 +1300
> +++ 2_queries-sparcv7.out 2005-10-13 12:07:43.660007000 +1300
> @@ -394,11 +395,11 @@
> SELECT AsText(Difference(named_places.boundary, forests.boundary))
> FROM named_places, forests
> WHERE named_places.name = 'Ashton' AND forests.name = 'Green Forest';
> astext
> - POLYGON((56 34,62 48,84 48,84 42,56 34 ))
> + POLYGON(( 62 48,84 48,84 42,56 34,62 48))
> (1 row)
> @@ -426,8 +427,8 @@
> SELECT AsText(ConvexHull(shore))
> FROM lakes
> WHERE lakes.name = 'Blue Lake';
> astext
> - POLYGON(( 52 18,66 23,73 9,48 6,52 18))
> + POLYGON((48 6,52 18,66 23,73 9,48 6 ))
> (1 row)
> NOT SO GOOD (sparcv9):
> The 64bit build on the sparcv9 arch has a few problems, here is a diff-u on that (again 1 space indented and edited out trailing contexts)...
> --- 2_queries.correct 2005-10-13 14:10:23.414031000 +1300
> +++ 2_queries-sparcv9.out 2005-10-11 17:10:09.050419000 +1300
> @@ -74,22 +74,19 @@
> SELECT AsText(boundary)
> FROM named_places
> WHERE name = 'Goose Island';
> astext
> - POLYGON( ( 67 13, 67 18, 59 18, 59 13, 67 13) )
> + POLYGON( EMPTY, EMPTY, EMPTY)
> (1 row)
> SELECT AsText(PolygonFromWKB(AsBinary(boundary)))
> FROM named_places
> - astext
> -(1 row)
> +psql:2_queries.sql:243: ERROR: Invalid type in wbk
> +CONTEXT: SQL function "polygonfromwkb" statement 1
> @@ -114,20 +111,20 @@
> SELECT AsText(Boundary(boundary))
> FROM named_places
> astext
> - LINESTRING( 67 13, 67 18, 59 18, 59 13, 67 13 )
> + LINESTRING EMPTY
> (1 row)
> SELECT AsText(Envelope(boundary))
> FROM named_places
> astext
> - POLYGON( ( 59 13, 59 18, 67 18, 67 13, 59 13) )
> + POLYGON EMPTY
> (1 row)
> @@ -226,12 +223,12 @@
> SELECT AsText(ExteriorRing(shore))
> FROM lakes
> WHERE name = 'Blue Lake';
> astext
> - LINESTRING(52 18, 66 23, 73 9, 48 6, 52 18)
> + LINESTRING EMPTY
> (1 row)
> @@ -242,12 +239,12 @@
> SELECT AsText(InteriorRingN(shore, 1))
> FROM lakes
> astext
> - LINESTRING(59 18, 67 18, 67 13, 59 13, 59 18)
> + LINESTRING(59 18)
> (1 row)
> @@ -258,12 +255,12 @@
> SELECT AsText(GeometryN(centerlines, 2))
> FROM divided_routes
> WHERE name = 'Route 75';
> astext
> - LINESTRING( 16 0, 16 23, 16 48 )
> + LINESTRING(16 0,16 23)
> (1 row)
> @@ -393,31 +390,19 @@
> - astext
> -POLYGON( ( 56 34, 62 48, 84 48, 84 42, 56 34) )
> -(1 row)
> +psql:2_queries.sql:922: ERROR: invalid memory alloc request size 1073741824
> SELECT AsText(GeomUnion(shore, boundary))
> FROM lakes, named_places
> WHERE lakes.name = 'Blue Lake' AND named_places.name = 'Goose Island';
> - astext
> -POLYGON((52 18,66 23,73 9,48 6,52 18))
> -(1 row)
> +psql:2_queries.sql:936: ERROR: invalid memory alloc request size 1073741824
> SELECT AsText(SymmetricDifference(shore, boundary))
> - astext
> -(1 row)
> +psql:2_queries.sql:951: ERROR: invalid memory alloc request size 1073741824
> @@ -426,9 +411,9 @@
> FROM lakes
> astext
> - POLYGON((52 18,66 23,73 9,48 6,52 18))
> + POLYGON EMPTY
> (1 row)
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
