[postgis-devel] Some thoughts on Topology
Charles F. I. Savage
cfis at interserv.com
Thu Oct 27 10:42:50 PDT 2005
Hi everyone,
I have a few questions/thoughts about the recently committed topology
support in PostGIS. In no particular order:
1. I am a bit worried about duplication of information. Each
topogeometry may include many topology primitives (edges, nodes), but is
always assigned to one layer. Thus it seems to me the layer_id column
in the relations column contains redundant information (i.e., is not
normalized fully). I think this matters because its easy to imagine a
large database where the relation table would contain millions, if not
billions (well no more than 4 billion since the model uses int4) of
records. What about doing something like this instead:
REATE TABLE city_data.topogeometry
topogeo_id int4 DEFAULT nextval("topogeometry_id_seq") NOT NULL,
layer_id int4,
CONSTRAINT topogeometry_key UNIQUE (topogeo_id)
REATE TABLE city_data.relation
topogeo_id int4 NOT NULL,
element_id int4 NOT NULL,
element_type int4 NOT NULL,
CONSTRAINT relation_layer_id_key UNIQUE (topogeo_id, element_id,
element_type)
I think this change would also remove the need for having the separate
topogeometry type. In feature tables with topogeometry columns you
would just specify the topogeom id directly instead of using the more
complex topogeometry type (which also seems to me to contain a lot of
unnecessary, redundant information).
I could also imagine you may wish to add "mbr" column to the
topogeometry column for quicker spatial scans. This would work for all
types of topogeometries, instead of just faces as the current
implementation does (with the mbr column in the faces table, which would
be removed with this change).
2. Next, is it possible to remove the element_type column from relation
and move it to the proposed topogeometry table? I can see the argument
that it belongs in the relation table if you have topogeometries that
consist of different types of topo primitives. However, I'm not sure
I've ever seen the need for a such a thing.
From my experience, its sufficient to support points (maps to nodes),
linear topology features (i.e., a topology made up of a number of edges)
and area topology features (also made up of edges). Of course a linear
topology feature is made up of edges and nodes, but the edges already
know about the nodes so there is no reason to duplicate that information.
If this is correct, then I'd move the element_type colum to the
topogeometry table and eliminate it from the relation table. If this is
not correct, then maybe someone could provide an example where this is
needed so I could understand it better?
3. I see the implementation quite closely matches what Oracle has
done. Out of curiosity, is this done to meet the SQL MM standard
(unfortunately I don't have a copy of the standard and don't feel like
paying a few hundred dollars to buy it), or simply to stay close to what
Oracle has done?
Interested in hearing feedback to these ideas,
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20051027/aa0b18c9/attachment.bin>
