[postgis-devel] news from the head branch
strk at refractions.net strk at refractions.net
Mon Sep 26 08:17:24 PDT 2005
Just to keep you in sync about devs on the HEAD branch:
	- added a LineMerge function (using GEOS)
	- added initial interface for the GEOS C api
A few words about the GEOS-CAPI interface.
The GEOS C api (still poorly tested) provides an abstraction
layer aimed at protecting library binary interface.
This means that if you link postgis against the ligeos_c.so,
you theoretically would not be required to rebuild it when
upgrading GEOS. New GEOS installation would override the
libgeos_c.so file so to attach it to new GEOS library.
If you want to join the exciting segfaults adventure:
	- get GEOS head branch from CVS and install it
	- get PostGIS head branch, configure adding --with-geos-capi
	  and instal it
--strk;
