[postgis-devel] GCC4 errors
Devrim GUNDUZ devrim at gunduz.org
Tue Sep 27 15:02:45 PDT 2005
While trying to build PostGIS on Fedora Core 4, I got many errors and
warnings:
Compiling it with CFLAGS=-Wno-pointer-sign surpresses warnings ;) ;
however we have another problem:
lwgeom_gist.c: In function 'LWGEOM_gist_consistent':
lwgeom_gist.c:624: error: 'StrategyNumber' undeclared (first use in this
function)
lwgeom_gist.c:624: error: (Each undeclared identifier is reported only
once
lwgeom_gist.c:624: error: for each function it appears in.)
lwgeom_gist.c:624: error: syntax error before 'strategy'
lwgeom_gist.c:647: warning: pointer targets in passing argument 1 of
'getbox2d_p' differ in signedness
lwgeom_gist.c:655: error: 'strategy' undeclared (first use in this
function)
lwgeom_gist.c: At top level:
lwgeom_gist.c:668: error: syntax error before 'StrategyNumber'
lwgeom_gist.c:669: warning: 'lwgeom_rtree_internal_consistent' was used
with no prototype before its definition
lwgeom_gist.c: In function 'lwgeom_rtree_internal_consistent':
lwgeom_gist.c:669: warning: old-style function definition
lwgeom_gist.c:676: error: 'strategy' undeclared (first use in this
function)
lwgeom_gist.c:678: error: 'key' undeclared (first use in this function)
lwgeom_gist.c:678: error: 'query' undeclared (first use in this function)
lwgeom_gist.c:750: error: syntax error before 'StrategyNumber'
lwgeom_gist.c:751: warning: 'lwgeom_rtree_leaf_consistent' was used with
lwgeom_gist.c: In function 'lwgeom_rtree_leaf_consistent':
lwgeom_gist.c:751: warning: old-style function definition
lwgeom_gist.c:758: error: 'strategy' undeclared (first use in this
function)
lwgeom_gist.c:761: error: 'key' undeclared (first use in this function)
lwgeom_gist.c:761: error: 'query' undeclared (first use in this function)
make[1]: *** [lwgeom_gist.o] Error 1
make: *** [liblwgeom] Error 2
I'll try to fix all GCC4 warnings ( I mean, like "lwgeom_gist.c:463:
warning: pointer targets in passing argument 1 of 'getbox2d_p' differ in
signedness"), but I could not see the fix for the above.
Any comments?
Regards,
Devrim GUNDUZ
Kivi Bilişim Teknolojileri - http://www.kivi.com.tr
devrim~gunduz.org, devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
                       http://www.gunduz.org
