[postgis-devel] GCC4 errors
Devrim GUNDUZ devrim at gunduz.org
Thu Sep 29 07:20:38 PDT 2005
On Thu, 29 Sep 2005, Mark Cave-Ayland wrote:
> I haven't checked latest CVS (head is currently 1.1) but I can't see that
> you would have any problems with either that or the 1.0 (pgis_1_0) branch.
> What happens if you do a "make clean" on your PostgreSQL/PostGIS installs
> and rebuild from scratch? I'd tend to agree with strk that it's some kind of
> header file problem but other than that it's difficult to say.
Ok it seems that you are right. There was a weird problem in the spec file
I used. The weirdness is that I was using this spec in 1.0.0 and 1.0.1.
Anyway, I've changed it and all works fine.
Regards
Devrim GUNDUZ
Kivi Bilişim Teknolojileri - http://www.kivi.com.tr
devrim~gunduz.org, devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
                       http://www.gunduz.org
