[postgis-devel] PostGis Installation Problems
Albert Leibbrandt evlangelis at gmail.com
Mon Apr 3 12:40:22 PDT 2006
Hi
I have installed GEOS 2.2.1 from source and am know trying to install
postgis 1.1.2.
postgis is throwing out the following error when I run configure:
lwgeom_transform.c: In function `pj_transform_nodatum':
lwgeom_transform.c:545: error: structure has no member named `is_latlong'
lwgeom_transform.c:564: error: structure has no member named `is_latlong'
lwgeom_transform.c: In function `transform_point':
lwgeom_transform.c:973: error: structure has no member named `is_latlong'
lwgeom_transform.c:974: warning: implicit declaration of function
`pj_transform'
lwgeom_transform.c:994: error: structure has no member named `is_latlong'
make[1]: *** [lwgeom_transform.o] Error 1
make[1]: Leaving directory `/www/postgis-1.1.2/lwgeom'
make: *** [liblwgeom] Error 2
Has anybody got any ideas what is going wrong here and what can be done
to rectify the problem.
I'm running on redhat enterprise server 4 with postgresql 7.4
Any and all ideas will be appreciated.
Thanks
Albert
