[postgis-devel] probe_geometry_columns
Chris Hodgson chodgson at refractions.net
Tue Apr 11 11:02:07 PDT 2006
Sounds sweet. Perhaps "repair_geometry_columns"? Or, there used to be a
"fix_geometry_columns" I think... I'm not sure what the original "probe"
and/or fix did but this sounds pretty full-featured.
Chris
Kevin Neufeld wrote:
> Hello all,
> I've created a more robust version of the probe_geometry_columns
> function. Often, during development, many spatial tables are formed and
> more often than not, developers can't be bothered to religiously use the
> add/dropgeometrycolumn methods when creating or dropping tables.
> Unfortunately, the probe_geometry_columns does not deal with these
> spatial columns (ie. CREATE TABLE mytbl (LIKE somespatialtable) .... or
> CREATE TABLE mytbl AS SELECT * FROM somespatialtable...)
> This version of probe_geometry_columns (that I've temporarily dubbed
> populate_geometry_columns) will
>   1. truncate geometry_columns
>   2. using the system tables, insert all spatial columns to
> geometry_columns where spatial constraints exists
>   3. probe remaining columns for srid, ndims, and geotype, apply
> necessary table constraints, and insert the spatial column into
> geometry_columns.
>   4. gracefully throw a warning if the srid/ndims/geotype values could
> not be determined (ie. empty table or null geometries)
> Let me know if you think this might be useful.
> Cheers,
> Kevin.
> -- Function: public.populate_geometry_columns()
> -- DROP FUNCTION public.populate_geometry_columns()
> CREATE OR REPLACE FUNCTION public.populate_geometry_columns()
>   RETURNS text AS
> $BODY$
> DECLARE
>     inserted    integer;
>     oldcount    integer;
>     probed      integer;
>     stale       integer;
>     gcs         RECORD;
>     gc          RECORD;
>     gsrid       integer;
>     gsrid_cnt   integer;
>     gndims      integer;
>     gndims_cnt  integer;
>     gtype       text;
>     gtype_cnt   text;
> BEGIN
>     SELECT count(*) INTO oldcount FROM geometry_columns;
>     inserted := 0;
>     EXECUTE 'TRUNCATE geometry_columns';
>     SELECT count(*) INTO probed
>         FROM pg_class c,
>              pg_attribute a,
>              pg_type t,
>              pg_namespace n
>         WHERE c.relkind = 'r'
>         AND t.typname = 'geometry'
>         AND a.attisdropped = false
>         AND a.atttypid = t.oid
>         AND a.attrelid = c.oid
>         AND c.relnamespace = n.oid;
>     -- Iterate through all non-dropped geometry columns
>     FOR gcs IN
>         SELECT n.nspname, c.relname, a.attname
>             FROM pg_class c,
>                  pg_attribute a,
>                  pg_type t,
>                  pg_namespace n
>         LOOP
>         RAISE INFO 'Processing %.%.%', gcs.nspname, gcs.relname, gcs.attname;
>         -- Try to find srid check from system tables (pg_constraint)
>         gsrid :=
>             (SELECT replace(split_part(s.consrc, ' = ', 2), ')', '')
>              FROM pg_class c, pg_namespace n, pg_attribute a, pg_constraint s
>              WHERE n.nspname = gcs.nspname
>              AND c.relname = gcs.relname
>              AND a.attname = gcs.attname
>              AND s.connamespace = n.oid
>              AND s.conrelid = c.oid
>              AND a.attnum = ANY (s.conkey)
>              AND s.consrc LIKE '%srid(% = %');
>         GET DIAGNOSTICS gsrid_cnt = ROW_COUNT;
>         IF (gsrid_cnt = 0 OR gsrid IS NULL) THEN
>             -- Try to find srid from the geometry itself
>             EXECUTE 'SELECT public.srid(' || quote_ident(gcs.attname) || ')
>                      FROM ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) || '
>                      WHERE ' || quote_ident(gcs.attname) || ' IS NOT NULL LIMIT 1'
>                 INTO gc;
>             gsrid := gc.srid;
>             -- Try to apply srid check to column
>             IF (gsrid IS NOT NULL) THEN
>                 BEGIN
>                     EXECUTE 'ALTER TABLE ' || quote_ident(gcs.nspname) || '.' || quote_ident(gcs.relname) || '
>                              ADD CONSTRAINT ' || quote_ident('enforce_srid_' || gcs.attname) || '
>                              CHECK (srid(' || quote_ident(gcs.attname) || ') = ' || gsrid || ')';
>                 EXCEPTION
>                     WHEN check_violation THEN
>                         RAISE NOTICE 'Could not apply constraint CHECK (srid(%) = %) to %.%', quote_ident(gcs.attname), gsrid, quote_ident(gcs.nspname), quote_ident(gcs.relname);
>                 END;
>             END IF;
>         END IF;
>         -- Try to find ndims check from system tables (pg_constraint)
>         gndims :=
>              AND s.consrc LIKE '%ndims(% = %');
>         GET DIAGNOSTICS gndims_cnt = ROW_COUNT;
>         IF (gndims_cnt = 0 OR gndims IS NULL) THEN
>             -- Try to find ndims from the geometry itself
>             EXECUTE 'SELECT public.ndims(' || quote_ident(gcs.attname) || ')
>                 INTO gc;
>             gndims := gc.ndims;
>             -- Try to apply ndims check to column
>             IF (gndims IS NOT NULL) THEN
>                 BEGIN
>                              ADD CONSTRAINT ' || quote_ident('enforce_dims_' || gcs.attname) || '
>                              CHECK (ndims(' || quote_ident(gcs.attname) || ') = '||gndims||')';
>                 EXCEPTION
>                         RAISE NOTICE 'Could not apply constraint CHECK (ndims(%) = %) to %.%', quote_ident(gcs.attname), gndims, quote_ident(gcs.nspname), quote_ident(gcs.relname);
>                 END;
>             END IF;
>         END IF;
>         -- Try to find geotype check from system tables (pg_constraint)
>         gtype :=
>             (SELECT replace(split_part(s.consrc, '\'', 2), ')', '')
>              AND s.consrc LIKE '%geometrytype(% = %');
>         GET DIAGNOSTICS gtype_cnt = ROW_COUNT;
>         IF (gtype_cnt = 0 OR gtype IS NULL) THEN
>             -- Try to find geotype from the geometry itself
>             EXECUTE 'SELECT public.geometrytype(' || quote_ident(gcs.attname) || ')
>                 INTO gc;
>             gtype := gc.geometrytype;
>             -- Try to apply geometrytype check to column
>             IF (gtype IS NOT NULL) THEN
>                 BEGIN
>                     ADD CONSTRAINT ' || quote_ident('enforce_geotype_' || gcs.attname) || '
>                     CHECK ((geometrytype(' || quote_ident(gcs.attname) || ') = ' || quote_literal(gtype) || ') OR (' || quote_ident(gcs.attname) || ' IS NULL))';
>                 EXCEPTION
>                         RAISE NOTICE 'Could not apply constraint CHECK ((geometrytype(%) = %) OR (% IS NULL)) to %.%', quote_ident(gcs.attname), quote_literal(gtype), quote_ident(gcs.attname), quote_ident(gcs.nspname), quote_ident(gcs.relname);
>                 END;
>             END IF;
>         END IF;
>             RAISE WARNING 'Could not determine the srid of \'%\' in \'%.%\'', gcs.attname, gcs.nspname, gcs.relname;
>         ELSIF (gndims_cnt = 0 OR gndims IS NULL) THEN
>             RAISE WARNING 'Could not determine the number of dimensions of \'%\' in \'%.%\'', gcs.attname, gcs.nspname, gcs.relname;
>         ELSIF (gtype_cnt = 0 OR gtype IS NULL) THEN
>             RAISE WARNING 'Could not determine the geometry type of \'%\' in \'%.%\'', gcs.attname, gcs.nspname, gcs.relname;
>         ELSE
>             INSERT INTO geometry_columns (f_table_catalog,f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, type)
>             VALUES ('', gcs.nspname, gcs.relname, gcs.attname, gndims, gsrid, gtype);
>             inserted := inserted + 1;
>         END IF;
>     END LOOP;
>     IF oldcount > inserted THEN
>         stale = oldcount-inserted;
>     ELSE
>         stale = 0;
>     END IF;
>         RETURN 'probed:' ||probed|| ' inserted:'||inserted|| ' conflicts:'||probed-inserted|| ' deleted:'||stale;
> END
> $BODY$
>   LANGUAGE 'plpgsql' VOLATILE;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
