[postgis-devel] probe_geometry_columns
strk at refractions.net strk at refractions.net
Tue Apr 11 11:08:52 PDT 2006
The fix_geometry_columns was a quick hack.
I'm sure this is better.
My only concern is compatibility back to PostgreSQL 7.2.
Is there any volunteer for back-porting ?
--strk;
On Tue, Apr 11, 2006 at 11:02:07AM -0700, Chris Hodgson wrote:
> Sounds sweet. Perhaps "repair_geometry_columns"? Or, there used to be a
> "fix_geometry_columns" I think... I'm not sure what the original "probe"
> and/or fix did but this sounds pretty full-featured.
> Chris
> Kevin Neufeld wrote:
> >Hello all,
> >I've created a more robust version of the probe_geometry_columns
> >function. Often, during development, many spatial tables are formed and
> >more often than not, developers can't be bothered to religiously use the
> >add/dropgeometrycolumn methods when creating or dropping tables.
> >Unfortunately, the probe_geometry_columns does not deal with these
> >spatial columns (ie. CREATE TABLE mytbl (LIKE somespatialtable) .... or
> >CREATE TABLE mytbl AS SELECT * FROM somespatialtable...)
> >This version of probe_geometry_columns (that I've temporarily dubbed
> >populate_geometry_columns) will
> >  1. truncate geometry_columns
> >  2. using the system tables, insert all spatial columns to
> >geometry_columns where spatial constraints exists
> >  3. probe remaining columns for srid, ndims, and geotype, apply
> >necessary table constraints, and insert the spatial column into
> >geometry_columns.
> >  4. gracefully throw a warning if the srid/ndims/geotype values could
> >not be determined (ie. empty table or null geometries)
> >Let me know if you think this might be useful.
> >Cheers,
> >Kevin.
> >-- Function: public.populate_geometry_columns()
> >-- DROP FUNCTION public.populate_geometry_columns()
> >CREATE OR REPLACE FUNCTION public.populate_geometry_columns()
> >  RETURNS text AS
> >$BODY$
> >DECLARE
> >    inserted    integer;
> >    oldcount    integer;
> >    probed      integer;
> >    stale       integer;
> >    gcs         RECORD;
> >    gc          RECORD;
> >    gsrid       integer;
> >    gsrid_cnt   integer;
> >    gndims      integer;
> >    gndims_cnt  integer;
> >    gtype       text;
> >    gtype_cnt   text;
> >BEGIN
> >    SELECT count(*) INTO oldcount FROM geometry_columns;
> >    inserted := 0;
> >    EXECUTE 'TRUNCATE geometry_columns';
> >    SELECT count(*) INTO probed
> >        FROM pg_class c,
> >             pg_attribute a,
> >             pg_type t,
> >             pg_namespace n
> >        WHERE c.relkind = 'r'
> >        AND t.typname = 'geometry'
> >        AND a.attisdropped = false
> >        AND a.atttypid = t.oid
> >        AND a.attrelid = c.oid
> >        AND c.relnamespace = n.oid;
> >    -- Iterate through all non-dropped geometry columns
> >    FOR gcs IN
> >        SELECT n.nspname, c.relname, a.attname
> >            FROM pg_class c,
> >                 pg_attribute a,
> >                 pg_type t,
> >                 pg_namespace n
> >        LOOP
> >        RAISE INFO 'Processing %.%.%', gcs.nspname, gcs.relname,
> >        gcs.attname;
> >        -- Try to find srid check from system tables (pg_constraint)
> >        gsrid :=
> >            (SELECT replace(split_part(s.consrc, ' = ', 2), ')', '')
> >             FROM pg_class c, pg_namespace n, pg_attribute a,
> >             pg_constraint s WHERE n.nspname = gcs.nspname
> >             AND c.relname = gcs.relname
> >             AND a.attname = gcs.attname
> >             AND s.connamespace = n.oid
> >             AND s.conrelid = c.oid
> >             AND a.attnum = ANY (s.conkey)
> >             AND s.consrc LIKE '%srid(% = %');
> >        GET DIAGNOSTICS gsrid_cnt = ROW_COUNT;
> >        IF (gsrid_cnt = 0 OR gsrid IS NULL) THEN
> >            -- Try to find srid from the geometry itself
> >            EXECUTE 'SELECT public.srid(' || quote_ident(gcs.attname) ||
> >            ') FROM ' || quote_ident(gcs.nspname) || '.' ||
> >                     quote_ident(gcs.relname) || ' WHERE ' ||
> >                     quote_ident(gcs.attname) || ' IS NOT NULL LIMIT 1' INTO gc;
> >            gsrid := gc.srid;
> >            -- Try to apply srid check to column
> >            IF (gsrid IS NOT NULL) THEN
> >                BEGIN
> >                    EXECUTE 'ALTER TABLE ' || quote_ident(gcs.nspname) ||
> >                    '.' || quote_ident(gcs.relname) || ' ADD
> >                             CONSTRAINT ' || quote_ident('enforce_srid_'
> >                             || gcs.attname) || ' CHECK (srid(' ||
> >                             quote_ident(gcs.attname) || ') = ' || gsrid
> >                EXCEPTION
> >                    WHEN check_violation THEN
> >                        RAISE NOTICE 'Could not apply constraint CHECK
> >                        (srid(%) = %) to %.%', quote_ident(gcs.attname),
> >                        gsrid, quote_ident(gcs.nspname),
> >                        quote_ident(gcs.relname);
> >                END;
> >            END IF;
> >        END IF;
> >        -- Try to find ndims check from system tables (pg_constraint)
> >        gndims :=
> >             AND s.consrc LIKE '%ndims(% = %');
> >        GET DIAGNOSTICS gndims_cnt = ROW_COUNT;
> >        IF (gndims_cnt = 0 OR gndims IS NULL) THEN
> >            -- Try to find ndims from the geometry itself
> >            EXECUTE 'SELECT public.ndims(' || quote_ident(gcs.attname) ||
> >            gndims := gc.ndims;
> >            -- Try to apply ndims check to column
> >            IF (gndims IS NOT NULL) THEN
> >                BEGIN
> >                             CONSTRAINT ' || quote_ident('enforce_dims_'
> >                             || gcs.attname) || ' CHECK (ndims(' ||
> >                             '||gndims||')';
> >                EXCEPTION
> >                        (ndims(%) = %) to %.%', quote_ident(gcs.attname),
> >                        gndims, quote_ident(gcs.nspname),
> >                END;
> >            END IF;
> >        END IF;
> >        -- Try to find geotype check from system tables (pg_constraint)
> >        gtype :=
> >            (SELECT replace(split_part(s.consrc, '\'', 2), ')', '')
> >             AND s.consrc LIKE '%geometrytype(% = %');
> >        GET DIAGNOSTICS gtype_cnt = ROW_COUNT;
> >        IF (gtype_cnt = 0 OR gtype IS NULL) THEN
> >            -- Try to find geotype from the geometry itself
> >            EXECUTE 'SELECT public.geometrytype(' ||
> >            quote_ident(gcs.attname) || ') FROM ' ||
> >            gtype := gc.geometrytype;
> >            -- Try to apply geometrytype check to column
> >            IF (gtype IS NOT NULL) THEN
> >                BEGIN
> >                    '.' || quote_ident(gcs.relname) || ' ADD CONSTRAINT '
> >                    || quote_ident('enforce_geotype_' || gcs.attname) || '
> >                    CHECK ((geometrytype(' || quote_ident(gcs.attname) ||
> >                    ') = ' || quote_literal(gtype) || ') OR (' ||
> >                    quote_ident(gcs.attname) || ' IS NULL))';
> >                EXCEPTION
> >                        ((geometrytype(%) = %) OR (% IS NULL)) to %.%',
> >                        quote_ident(gcs.attname), quote_literal(gtype),
> >                        quote_ident(gcs.nspname), quote_ident(gcs.relname);
> >                END;
> >            END IF;
> >        END IF;
> >            RAISE WARNING 'Could not determine the srid of \'%\' in
> >            \'%.%\'', gcs.attname, gcs.nspname, gcs.relname;
> >        ELSIF (gndims_cnt = 0 OR gndims IS NULL) THEN
> >            RAISE WARNING 'Could not determine the number of dimensions of
> >            \'%\' in \'%.%\'', gcs.attname, gcs.nspname, gcs.relname;
> >        ELSIF (gtype_cnt = 0 OR gtype IS NULL) THEN
> >            RAISE WARNING 'Could not determine the geometry type of \'%\'
> >        ELSE
> >            INSERT INTO geometry_columns (f_table_catalog,f_table_schema,
> >            f_table_name, f_geometry_column, coord_dimension, srid, type)
> >            VALUES ('', gcs.nspname, gcs.relname, gcs.attname, gndims,
> >            gsrid, gtype);
> >            inserted := inserted + 1;
> >        END IF;
> >    END LOOP;
> >    IF oldcount > inserted THEN
> >        stale = oldcount-inserted;
> >    ELSE
> >        stale = 0;
> >    END IF;
> >        RETURN 'probed:' ||probed|| ' inserted:'||inserted|| '
> >        conflicts:'||probed-inserted|| ' deleted:'||stale;
> >END
> >$BODY$
> >  LANGUAGE 'plpgsql' VOLATILE;
> >_______________________________________________
> >postgis-devel mailing list
> >postgis-devel at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
