[postgis-devel] probe_geometry_columns
Kevin Neufeld kneufeld at refractions.net
Wed Apr 12 08:47:37 PDT 2006
Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net wrote:
>> The fix_geometry_columns was a quick hack.
>> I'm sure this is better.
>> My only concern is compatibility back to PostgreSQL 7.2.
>> Is there any volunteer for back-porting ?
> I think there won't be an easy way of back porting, as AFAIK the
> exception mechanism does not exist back then (as it internally uses
> savepoints / nested transactions which were introduced in 8.0, I think.)
Correct. The EXCEPTION clause was introduced in 8.0.
> My suggestion is to keep the existing geometry_column functions, and add
> this method under a different name for PostgreSQL 8.X only.
> Thanks,
> Markus
I could simply remove all the error catch clauses and just terminate the
function if an ADD CONSTRAINT query fails .... if that's desirable (as
well as adding code to support 7.2).
--Kevin
Kevin Neufeld,
Refractions Research Inc.,
Phone: (250) 383-3022
Fax:   (250) 383-2140
