[postgis-devel] probe_geometry_columns
Kevin Neufeld kneufeld at refractions.net
Wed Apr 12 08:51:26 PDT 2006
Markus Schaber wrote:
> Hi, Kevin,
> Kevin Neufeld wrote:
>>   3. probe remaining columns for srid, ndims, and geotype, apply
>> necessary table constraints, and insert the spatial column into
>> geometry_columns.
> >From looking at the code, it seems that this will not work fine for
> "mixed" geometry columns, which can be declared with 'GEOMETRY' as
> geometry type.
Right... forgot about that case. Will make the appropriate change.
Thx
Kevin Neufeld,
Refractions Research Inc.,
Phone: (250) 383-3022
Fax:   (250) 383-2140
